Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster!  It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game.  We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA and 2xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
        Nvidia GeForce GTX 280 1GB SLI
        Nvidia GeForce GTX 295 1,792MB
        Nvidia GeForce GTX 260-216 896MB SLI
        ATI Radeon HD 4870 1GB CrossFire
        ATI Radeon HD 4870 X2 2GB
        Zotac GeForce GTX 285 1GB AMP!
        Nvidia GeForce GTX 285 1GB
        HIS ATI Radeon HD 4870 1GB IceQ4+ Turbo
        ATI Radeon HD 4870 512MB
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Dropping the in-game settings down to high quality affords a better gameplay experience on the HIS Radeon HD 4870 1GB IceQ4+ Turbo and it'll enable you to increase the highest playable settings to 1,680 x 1,050 with 0xAA and 16xAF applied.  At this setting though, it's a good 17 percent slower than the GeForce GTX 260-216 896MB and, what's more, the competition from Nvidia has enough juice to deliver acceptable gameplay with 4xAA enabled as well although you'd probably settle on 2xAA for a much smoother experience.
